melgun7 Posted July 29, 2024 Posted July 29, 2024 I just bought a BuzzTV Classic. Downloaded a few Apps (Global TV, TSN, Sportsnet, CBC Gem). I'd like to be able to record something, but when I press the record button, nothing happens. I'm likely overlooking something simple and hoping someone can point me in the right direction. I've downloaded the manual, but it's really more of a quickstart guide than a manual. Not sure if a more detailed manual exists. Quote
nbs. Posted July 29, 2024 Posted July 29, 2024 Go to home page ,settings check updates and post what firmware and software are listed Which remote do you have? Quote
melgun7 Posted July 29, 2024 Author Posted July 29, 2024 Firmware: V20240202 IPTV Version: 5.0.935 BT-250 Remote Quote
Emporium Posted July 29, 2024 Posted July 29, 2024 FYI: Recording only work within the BuzzTV app with your IPTV subscription. Not with 3rd party apps (like you mentioned: Global TV, TSN, Sportsnet, CBC Gem). 1 Quote
melgun7 Posted July 29, 2024 Author Posted July 29, 2024 9 minutes ago, Emporium said: FYI: Recording only work within the BuzzTV app with your IPTV subscription. Not with 3rd party apps (like you mentioned: Global TV, TSN, Sportsnet, CBC Gem). Thanks for the feedback. I guess that's the problem. So I need to subscribe to some sort of IPTV package subscription? I already pay for TSN and Sportsnet subscriptions. 1 Quote
Emporium Posted July 29, 2024 Posted July 29, 2024 1 hour ago, melgun7 said: Thanks for the feedback. I guess that's the problem. So I need to subscribe to some sort of IPTV package subscription? I already pay for TSN and Sportsnet subscriptions. Yes, that is where a buzz box shines. Unfortunately, IPTV services are not allowed to be discussed on this Forum. However there are many other forums for that. Quote
