Chris1 Posted July 2, 2024 Posted July 2, 2024 I tried to move everything to the usb drive on the bottom of the box but the drive became inject by itself and now I try a factory reset but now the screen keeps going on and off I checked the power supply and the hdmi cord Quote
Emporium Posted July 2, 2024 Posted July 2, 2024 First of all the integrated drive location on the bottom of the U5, is NOT a USB drive bay, it is for a SATA drive. Did you try removing the drive all together to see if it behaves the same ? Is the drive a traditional mechanical drive, or an SSD ? I find that traditional mechanical drives tend to get extremely hot, since it is a non-ventilated compartment. I strongly recommend using a decent quality SSD drive, which typically get just slightly warm. When the drives get too hot, they will often auto-eject. You said you checked the power supply. Is it the original power supply which was provided with the U5 ? The U5 uses a 12V power supply, compared to most other buzz boxes which us a 5V power supply (xrs4900 is another exception). 2 Quote
Chris1 Posted July 2, 2024 Author Posted July 2, 2024 Yes I tried removing the drive and it still the same thing and use I am the 12v cord Quote
