nbs. Posted July 3, 2024 Posted July 3, 2024 When you power on it will try to connect to the last server you were using. 1 Quote
gheagy Posted July 3, 2024 Author Posted July 3, 2024 Hi, I've never used a M3U server, yet that's what my BuzzTV app tries to connect to. Quote
Emporium Posted July 3, 2024 Posted July 3, 2024 Something is for sure wrong. It should be like nbs mentions. And I know it is that, since sometimes I go over to my mom's and I switch server, and then after I leave she calls me to tell me that her channels are all different and she tried to reboot the machine and no difference. Then I have to guide her through changing servers, and she is good again and does not change through reboots When you are in your XC server, LiveTV, long press the "back" arrow to get the "Exit" dialog and then exit the LiveTV app. The M3U server, if you don't use it, then why not just delete it ? Quote
