Gian Posted May 30, 2024 Posted May 30, 2024 Hi I have a buzztv b5 and I am trying to not get the update on the app as it freezes very often. I tried uninstall updates and also did a factory reset but as soon as the box boots back up it updates the app buzz tv 5 ? Can I stop it ?As the box is freezing all the time and I even tried my subscription on my friend's box to make sure and it does not freeze on his,he has the unipro and tvplus pro boxes. Any help would be appreciated. Quote
dishuser Posted May 30, 2024 Posted May 30, 2024 23 minutes ago, Gian said: Hi I have a buzztv b5 and I am trying to not get the update on the app as it freezes very often. I tried uninstall updates and also did a factory reset but as soon as the box boots back up it updates the app buzz tv 5 ? Can I stop it ?As the box is freezing all the time and I even tried my subscription on my friend's box to make sure and it does not freeze on his,he has the unipro and tvplus pro boxes. Any help would be appreciated. have you tried the other video player? was your friend's box at your house or his? Quote
Gian Posted May 30, 2024 Author Posted May 30, 2024 Hi yes I did try the back up player My friend brought it here Quote
Emporium Posted May 30, 2024 Posted May 30, 2024 When you say you did a factory reset... Through the BuzzTV 5 menus, or using the PIN hardware method ? I did have one box that had issues at one point and the only thing that fixed it was a HARDWARE (pin method) reset. Quote
