Benoke Posted March 2, 2024 Posted March 2, 2024 Hi there, I have two boxes and used a stereo headset hooked up to the optical on my living room tv. It stopped working. So switched it for my bedroom box and it worked for three weeks and now it stopped working too, just the optical nothing else. Is there a setting that I need to change? thanks Quote
Benoke Posted March 2, 2024 Author Posted March 2, 2024 1 hour ago, Benoke said: The newest ones 2 Quote
nbs. Posted March 2, 2024 Posted March 2, 2024 That's not an answer You need to post firmware and software version too 1 Quote
Benoke Posted March 3, 2024 Author Posted March 3, 2024 My box is a x5 128AL firm V20230815 5.0.919 does that help? Quote
Emporium Posted March 3, 2024 Posted March 3, 2024 Have you checked under Settings->Device Preferences->Display and Sound->Advanced sound settings, and make sure that S/PDIF is still turned on ? It can happen sometimes after a s/w update some settings, like S/PDIF and Force Max Volume, will sometimes toggle. I know it is not ideal, but it does happen sometimes. 4 Quote
