H Gawad Posted July 21, 2019 Share Posted July 21, 2019 I have a xpl3000 unit that it always crash if you scroll up or down on the channel guide. This happens by either the arrows or page up/down buttons, anyone came across this, is there a fix for it? unit info is attached. Quote Link to comment Share on other sites More sharing options...
nbs. Posted July 21, 2019 Share Posted July 21, 2019 what version of buzz are you at? Have you cleared cache? have you cleared data? Quote Link to comment Share on other sites More sharing options...
H Gawad Posted July 22, 2019 Author Share Posted July 22, 2019 Thank you for the response. It is Buzz2. Yes for the clearing cache, yes for data aw well. I also noticed that even when I try to scroll (live TV, menu, updates) it crashes as well! Quote Link to comment Share on other sites More sharing options...
Stugots Posted July 22, 2019 Share Posted July 22, 2019 8 hours ago, H Gawad said: Thank you for the response. It is Buzz2. Yes for the clearing cache, yes for data aw well. I also noticed that even when I try to scroll (live TV, menu, updates) it crashes as well! either you have a old version of buzztv app (go to menu, check for update) or your box memory is almost full. go into android settings to see how much memory you have available Quote Link to comment Share on other sites More sharing options...
