Nunzio D Posted February 12, 2024 Posted February 12, 2024 can any one help I did a hard reset but it did not help These are the problems I am having with the box. Box does not recognize neither SATA Hard drive or micro SD card when trying to back up. But when I go into storage it shows the SATA Drive & the SD card Box does not recognize neither SATA Hard drive or micro SD card when try to direct where to record in the PVR options. Box gets extremely hot when SATA Hard Drive is in the unit, It seems when Hard Drive is in the unit, unit starts to Buffer more. Box will reboot itself when feels like it. It just started when turning on box Bluetooth bar comes up and won't shut off even when It ask me to close App. Must start box at least 2 to 4 times. In setting the back up & restore is not there Quote
dishuser Posted February 12, 2024 Posted February 12, 2024 (edited) you can only backup to internal then move it to another drive and use ssd instead of sata or get a fan Edited February 12, 2024 by dishuser Quote
Emporium Posted February 12, 2024 Posted February 12, 2024 (edited) OK let's start by stating, WHAT firmware version are you running (should be in the updates screen V202xxxxxx). Also what version of Buzztv software are you running (from live TV, if you click on menu, you should see it at the bottom of the screen (5.0.xxx). Secondly, item #1 and #6 contradict each other. #1 says that trying to backups you can't see the disk and SD card. #6 says that backup and restore is not there. I can tell you that for Android 9 boxes, you will NOT have the option to backup to SATA HDD or MicroSD. It backs up to internal and you should use a file manager tool to copy to any location you prefer. Also, Are you using a traditional mechanical HDD or an SSD ? I strongly recommend you use an SSD intead of mechanical. Traditional mechanical drives will generate a lot of heat (especially in enclosed area). This will throttle the CPU (which will slow it down and buffer), and eventually get it to act up. Also, don't try to use a MicroSD card. They were never designed for the kind of writes a PVR will do, and thy will fail prematurely. Edited February 12, 2024 by Emporium Quote
dishuser Posted February 12, 2024 Posted February 12, 2024 and format your drives to exfat format with a pc 1 Quote
Nunzio D Posted February 12, 2024 Author Posted February 12, 2024 6 minutes ago, Emporium said: OK let's start by stating, WHAT firmware version are you running (should be in the updates screen V202xxxxxx). Also what version of Buzztv software are you running (from live TV, if you click on menu, you should see it at the bottom of the screen (5.0.xxx). Secondly, item #1 and #6 contradict each other. #1 says that trying to backups you can't see the disk and SD card. #6 says that backup and restore is not there. I can tell you that for Android 9 boxes, you will NOT have the option to backup to SATA HDD or MicroSD. It backs up to internal and you should use a file manager tool to copy to any location you prefer. Also, Are you using a traditional mechanical HDD or an SSD ? I strongly recommend you use an SSD intead of mechanical. Traditional mechanical drives will generate a lot of heat (especially in enclosed area). This will throttle the CPU (which will slow it down and buffer), and eventually get it to act up. Also, don't try to use a MicroSD card. They were never designed for the kind of writes a PVR will do, and thy will fail prematurely. Under setting I Do Not have any option to back up & restore I have two 4900 boxes the one has it I was able to download to my sd card hoping to restore it to the other 4900 box Quote
dishuser Posted February 12, 2024 Posted February 12, 2024 3 minutes ago, Nunzio D said: Under setting I Do Not have any option to back up & restore I have two 4900 boxes the one has it I was able to download to my sd card hoping to restore it to the other 4900 box 3 minutes ago, Nunzio D said: Under setting I Do Not have any option to back up & restore I have two 4900 boxes the one has it I was able to download to my sd card hoping to restore it to the other 4900 box it's in menu/settings/configuration and you still haven't posted firmware/software versions Quote
dishuser Posted February 13, 2024 Posted February 13, 2024 and if you backed up to sd card it isn't there unless you moved it from internal Quote
Nunzio D Posted February 13, 2024 Author Posted February 13, 2024 23 hours ago, dishuser said: you can only backup to internal then move it to another drive and use ssd instead of sata or get a fan Will get the software version tomorrow when i get back home thanks Quote
Nunzio D Posted February 13, 2024 Author Posted February 13, 2024 23 hours ago, Emporium said: OK let's start by stating, WHAT firmware version are you running (should be in the updates screen V202xxxxxx). Also what version of Buzztv software are you running (from live TV, if you click on menu, you should see it at the bottom of the screen (5.0.xxx). Secondly, item #1 and #6 contradict each other. #1 says that trying to backups you can't see the disk and SD card. #6 says that backup and restore is not there. I can tell you that for Android 9 boxes, you will NOT have the option to backup to SATA HDD or MicroSD. It backs up to internal and you should use a file manager tool to copy to any location you prefer. Also, Are you using a traditional mechanical HDD or an SSD ? I strongly recommend you use an SSD intead of mechanical. Traditional mechanical drives will generate a lot of heat (especially in enclosed area). This will throttle the CPU (which will slow it down and buffer), and eventually get it to act up. Also, don't try to use a MicroSD card. They were never designed for the kind of writes a PVR will do, and thy will fail prematurely. Under setting when you have the Buzz tv app, it DOES NOT have back up or restore listed, But it shows in the storage in setting on the home page Quote
Nunzio D Posted February 13, 2024 Author Posted February 13, 2024 23 hours ago, Emporium said: OK let's start by stating, WHAT firmware version are you running (should be in the updates screen V202xxxxxx). Also what version of Buzztv software are you running (from live TV, if you click on menu, you should see it at the bottom of the screen (5.0.xxx). Secondly, item #1 and #6 contradict each other. #1 says that trying to backups you can't see the disk and SD card. #6 says that backup and restore is not there. I can tell you that for Android 9 boxes, you will NOT have the option to backup to SATA HDD or MicroSD. It backs up to internal and you should use a file manager tool to copy to any location you prefer. Also, Are you using a traditional mechanical HDD or an SSD ? I strongly recommend you use an SSD intead of mechanical. Traditional mechanical drives will generate a lot of heat (especially in enclosed area). This will throttle the CPU (which will slow it down and buffer), and eventually get it to act up. Also, don't try to use a MicroSD card. They were never designed for the kind of writes a PVR will do, and thy will fail prematurely. Yes I am using a SSD sata drive Quote
dishuser Posted February 13, 2024 Posted February 13, 2024 14 minutes ago, Nunzio D said: Under setting when you have the Buzz tv app, it DOES NOT have back up or restore listed, But it shows in the storage in setting on the home page I already posted where to find it Quote
