jim bince Posted January 19, 2024 Posted January 19, 2024 Since update. Buzztv x5 will not connect to wifi. Rebooted internet router and box no change works if connected other than wifi anyone having this problem 5 of my friends also same problem Quote
nbs. Posted January 19, 2024 Posted January 19, 2024 What firmware and software are you running ? Quote
Emporium Posted January 19, 2024 Posted January 19, 2024 Have you tried to FORGET the wifi and then manually select it again and re-enter password ? And when you say it does not connect, does it give you a particular error (like it thinks it is a wrong password), or does it just keep connecting/disconnecting ? If your router offers separate 2.4Ghz and 5Ghz bands, can you try connecting to the other one ? Quote
