thor1727 Posted October 24, 2023 Posted October 24, 2023 I bought a XRS4500 last year and am still on Buzz TV 4. I don't have any available update in the updates section and it says the beta is not available either. My current specs are: Firmware - V20211108 IPTV Version: 4.0.530 How can I get Buzz TV 4 update? Quote
nbs. Posted October 24, 2023 Posted October 24, 2023 30 minutes ago, thor1727 said: I bought a XRS4500 last year and am still on Buzz TV 4. I don't have any available update in the updates section and it says the beta is not available either. My current specs are: Firmware - V20211108 IPTV Version: 4.0.530 How can I get Buzz TV 4 update? check updates and when it says no update available type in 2015 on your remote a couple of times If your mac is on the list it will update If not email buzz and ask them to add your mac Quote
thor1727 Posted October 24, 2023 Author Posted October 24, 2023 Thanks @nbs. I understand that I need to email buzz. How can I do that? What is the email address and what are the details I need to send? Quote
nbs. Posted October 24, 2023 Posted October 24, 2023 (edited) 7 minutes ago, thor1727 said: Thanks @nbs. I understand that I need to email buzz. How can I do that? What is the email address and what are the details I need to send? Cs at buzztv.com They need your device id Did you try 2015? Edited October 24, 2023 by nbs. Quote
thor1727 Posted October 24, 2023 Author Posted October 24, 2023 Yes @nbs , I tried 2015. It sayd "No beta update available" Confirming the email address: cs@buzztv.com Correct? Quote
