Hi everyone, hope all is well.
I have 2 Classics in the same house, same internet provider, power conditioned, same server, and 1 is freezing after a few hours of being ON.
If it is unplugged for a few minutes, and restarted, it is fine for a few hours, then it freezes again.
Any ideas?
Thanks for the support
Mark7
Okay, swapped power supplies, same problem.
Going to try swapping the box locations, might be HDMI cable related? It's on a custom built media center.
Thanks, Mark7
Does it get any airflow in the media center ?  I have a few boxes on my desk, and if I forget and put something on top of them they can get pretty warm.  OK, mine are not in any enclosed area, so they don't "overheat", but if they were in an enclosed area with little airflow, I am pretty sure some of them "could" get hotter than what they "should" be.
Okay, both boxes have adequate air flow, not Hot.
Switched installations, same box, same freezing, so not HDMI, Power supply, Internet provider, or server,,,
Will swap it out, and bring it to Buzz next week.
Thanks everyone for your help.
Mark7
Yes all will be erased...  But for testing I guess you can just recreate one server for now.  Returning it anyhow, so not much to lose 🙂
Here is the link for reset of 4500, but procedue is same for most buzz untis:
https://www.youtube.com/watch?v=9l1x3KJl_jE
Hi everyone, the Hard Start seems to have fixed the Freezing problem. Thank you everyone for the support.
Side note: the server info did have to be reloaded. Fully expecting that.
Mark7
  • Like 3
