  • 2 months later...
Yeah but the Classics not listed I've tried all the different variations of buzz in the database the problem is you can't see the actual models you just have to type in the model number and hope it find something close but I haven't seen one of them yet that work with the classic in that database
I meant to say you type in the manufacturer name Buzz  it shows three different manufacturers,  buzz , buzz time and buzz TV and when I put the word classic under the model nothing comes up for any of the three
Edited by What2be
Look for the Buzz xrs4500 or xrs4900.  Remote is the same and those are in the harmony database.
They have "BUZZTV XRS 4900", "BUZTV XRS4500" and "BUZZTV XRS 4000"  Either one should work.
Hey, even the X5 is listed - and it will work also.
Edited by Emporium
