Weird Arrow
Using real debrid and all of the sudden I cannot authorize my codes to connect. It just gets stuck in "please wait" with a round arrow. This arrow is now in all of my apps. It's never shown up before and I've had this box for a couple of years. Not looking to reset my entire box as I am afraid that I will lose all of my real debrid connections with my apps
There hasn't been any update on the 4500 in quite a while, so it is obviously not related to any changes on the buzz side.
Did you try rebooting your router/modem ?  I know many say "everything else works", but many times it is strange states of the router.
Also, have you tried with a VPN connection (some ISPs are starting to add block lists and throttling lists).
Other option would be to go through the apps in settings, and clearing the Cache.
Have you checked on another box (on your network), to confirm it is not real-debrid itself, a routing issues to real-debrid servers, or a DNS server issue ?
PS: This will be the last reply to this topic, since this is a BuzzTV support site, and in this case, it is NOT anything to do with the BuzzTV software on the BuzzTV box.  This is NOT the right forum for support on 3rd party apps (even if they are on a Buzz box).  There are other sites/forums you can discuss 3rd party app issues.
