M3U issue with live TV
abe
I downloaded M3U file using downloader app but when I went to the server and I put the M3U file link after connecting "Loading channel list..." has been showing for hours but it works with VLC app.  When I check for M3U in  App Installer it's not there.  Thanks in advance for any suggestions.
glad you got it.
for epg you need to enter epg url.
I would use XC option with username and password instead of m3u option if possible. with this option you enter url, username and password and thats it. I think its better option.
On 8/23/2021 at 4:05 PM, Ryu said:
glad you got it.
Remember there is issue with buzz not reading m3u file but I agree xc login option is better.
A lot of IPTV companies have already stopped allowing customers to use M3U lists but now they're also not allowing customers to use a MAC address because both those portals are security risks so the xtreme codes portal is absolutely the way to go
all 3 are at risk of being hacked
