RobertK Posted April 26, 2021 Posted April 26, 2021 i came home after work to discover the one month old Buzztv SRX4500max 'froze' it would not shut down. I unplugged the unit, waited and plugged it back in after the initial splash screen and the bottom menu appears the background can be seen but nothing overlaid. When I hit the power button text briefly appears 'Shutting down...' then it freezes and is no longer responsive was an update pushed out or something? short of a factory reset what (if anything) can I do ? frustrating because otherwise i have been very happy with this unit! R Quote
RobertK Posted April 27, 2021 Author Posted April 27, 2021 I did do a hard reset! Luckily I had a full backup as well! The unit came back after the reset. All is good now! Thank you for your reply! Quote
