sea157 Posted April 8, 2021 Posted April 8, 2021 Quick question. I have a XRS4500 MAX box all setup just how I like everything to be, I made a USB flash drive backup of it. My question is: Today I am getting a new XRS4500 Ultra for a second box. Can I use the backup I made for the XRS4500 Max and just load that onto my new XRS4500 Ultra in the restore function? If I can my new XRS4500 Ultra would be all setup just the way I like everything without me having to go into all the settings and set everything up again.XRS 1 Quote
sea157 Posted April 8, 2021 Author Posted April 8, 2021 59 minutes ago, nbs. said: Should work I will let you know, I am going to give it a try. Worst case I will need to do a factory reset on the box if it doesn't work. lol 1 Quote
sea157 Posted April 9, 2021 Author Posted April 9, 2021 Just an update, you CAN NOT use the backup file from a XRS4500 MAX box to do a restore on a XRS4500. I think the problem is the restore backup file is listed as xrs4500max_backup, and it never shown in the restore menu on a XRS4500 . I think you could only use this as a restore backup to another XRS4500 Max box. Quote
