My old BuzzTV XPL3000 had an brush / broom icon which you could select on the main screen to clean the memory and stop all running apps.  I believe you could also do this on old MyGica boxes by holding down the guide button for more than 3 seconds.
Is there a feature such as this on the BuzzTV xrs4500 either on screen or by holding down a button on the remote?
Thanks
