Recording programs
ezjob
Buzz Tv 5 will only record the channel I'm watching.
Is this supposed to be this way?
If I change the channel the recording stops.
Also, I set it to record at a certain time on a channel and it only recorded a few minutes of a 3 hour program.
Not good. I'm new to this Tv Box and so far I'm not impressed.
  • Haha 1
Does your IPTV provider allow you to have more then 1 connection to your service at a time?
To be able to record one and watch another your IPTV provider need to allow at least 2 connections at a time.
Example: My provider allows 4 connections at a time, I can record 3 different programs and watch 1 program all at the same time.
Because you are using two streams if you watch a channel while recording
That is why you can't watch another channel You can go and use an app netflix YouTube etc
You havnt posted any info on how you set up recording
Edited by nbs.
