225 Posted January 3, 2023 Posted January 3, 2023 Is there a setting to change from single epg to 2 line ? I looked but cant find out how to change it. Quote
Emporium Posted January 3, 2023 Posted January 3, 2023 Only single EPG source is supported at the moment. There are plans to eventually implement it, but no timeline for now. Quote
Emporium Posted January 3, 2023 Posted January 3, 2023 2 hours ago, dishuser said: so no one wants to explain? fine Lol.. If you checked the Link to allaboutbuzz's reply which I included in my reply, you would understand. Some people want to be able to add more than one EPG source. So one primary (as we have now), and then some other ones as secondary, etc.. to fill in the gaps that the primary one does not fulfill. It's not a bad idea, but the logic behind how to implement it can become a little messy, so it would certainly require quite a bit of testing. Some even asked for an option to add secondary EPG sources to XC subs. I would personally love to see support in M3U playlists for the url-tvg tag. That way, you can just provide a playlist, and the EPG url would be embedded in the M3U file. Example: #EXTM3U url-tvg="https://github.com/.../EPG/epg.xml" or even better yet, in .gz format which many EPG xml providers offer to significantly decrease the transfer since it is just text and super compressible. #EXTM3U url-tvg="https://github.com/.../EPG/epg.xml.gz" Quote
dishuser Posted January 4, 2023 Posted January 4, 2023 doesn't help when you disguise the link..lol 2 Quote
