Tim Haines Posted October 27, 2020 Posted October 27, 2020 Remote doesn't work any longer with stick. Not a battery issue. It has somehow unpaired. Followed instructions on back of remote with no luck. Help!! Quote
Tim Haines Posted October 28, 2020 Author Posted October 28, 2020 There is no IR cable that I am aware of. It only came with an HDMI cable. Never needed a cable? Quote
nbs. Posted October 28, 2020 Posted October 28, 2020 3 hours ago, Tim Haines said: There is no IR cable that I am aware of. It only came with an HDMI cable. Never needed a cable? The vidstick comes with an IR sensor cable .You plug it into the stick and your remote will work as an ir remote 1 Quote
