walk through
4 hours ago, marcoose said:
yes i got << but cant work out how to implement it ?
When on Full Screen Live TV
If the channel you're using has catchup available
Press the right arrow key on the remote
This will take you to the Single EPG for that channel.
And you will see the previous times and days which have the REW logo next to them
These all have catchup
You can also do the same by pressing the Guide button on the remote and going back in time on the Guide/EPG
The same goes on the channel list
If the channel has a REW logo next to it, press the right arrow key to view the Single EPG for that channel
From here you can access all of the catch up recordings for that channel.
