reviewerna Posted August 18, 2020 Posted August 18, 2020 Does anyone know how you can make the Aspect Ratio for channels to ALL be Full or 16:9? I noticed you have to go to each individual channel press the green button on the remote and select the aspect ratio for each channel which is so annoying I just wonder if there’s a easier way Please help Quote
nbs. Posted August 18, 2020 Posted August 18, 2020 (edited) Is your display set to auto? I do not have to change anything. Edited August 18, 2020 by nbs. Quote
reviewerna Posted August 18, 2020 Author Posted August 18, 2020 yes its set to auto but some channels still come as 4:3 and look terrible so you have ti press the green button and then you can pick stretch or 16:9 and then it looks perfecr but this setting only does it for just the one channel Quote
nbs. Posted August 18, 2020 Posted August 18, 2020 Sounds like the channels on the server are SD Quote
