tooldady Posted December 10, 2022 Share Posted December 10, 2022 (edited) Buzz Box X5 64AI V20221011 Just upgraded from 3000 to the X5 the live tv category organizing is different and am struggling to figure how to remove unwanted items any help much appreciated Edited December 10, 2022 by tooldady spelling Quote Link to comment Share on other sites More sharing options...
Emporium Posted December 10, 2022 Share Posted December 10, 2022 Do you want to remove complete categories, or have a list of channels with just the channels you want ? To hide categories, when you bring up the channel list, and you are in the categories list, check out the colored buttons on the bottom, the green one will say "Organize favorites". If you press the green button, you will see all the categories with checklist boxes next to them, and you can select which ones you want to see and/or hide. For channels, you can just select the channels you want, and press the yellow button to add to your Favorites list. Then you can just use the favorites category all the time. And even then, once you have the list of channels under "Favorites" category, you will see on the bottom again, colored buttons, I believe the Blue button, is to organize favorites, which will bring up another list with checkmarks where you can select channels, and then move them (reorder) within the favorite channel listing. 2 Quote Link to comment Share on other sites More sharing options...
tooldady Posted December 10, 2022 Author Share Posted December 10, 2022 Hi trying to remove and only have the categories we use listed i see the boxes to check after checking multiple categories to remove and clicking the yellow remove button only the category positioned inside the red line that does not move will be hid and not the multiple checks that i have made and then after hiding that one category that yellow button turns into a show button so i can not even remove them individually i am kinda stuck and confused Quote Link to comment Share on other sites More sharing options...
tooldady Posted December 10, 2022 Author Share Posted December 10, 2022 I also wanted to share that i tried hiding all categories and only showing the ones i want using the checked boxes and it does the same thing will only change the selected one inside the fixed line then the yellow button changes again Quote Link to comment Share on other sites More sharing options...
dishuser Posted December 10, 2022 Share Posted December 10, 2022 29 minutes ago, tooldady said: Hi trying to remove and only have the categories we use listed i see the boxes to check after checking multiple categories to remove and clicking the yellow remove button only the category positioned inside the red line that does not move will be hid and not the multiple checks that i have made and then after hiding that one category that yellow button turns into a show button so i can not even remove them individually i am kinda stuck and confused don't check the box just press yellow to hide Quote Link to comment Share on other sites More sharing options...
tooldady Posted December 10, 2022 Author Share Posted December 10, 2022 Made it work I had to hide them all with red button then had to show them individually with yellow button even though the yellow button did say hide after showing the first one it did still continue to show. Thank you for the help Quote Link to comment Share on other sites More sharing options...
dishuser Posted December 10, 2022 Share Posted December 10, 2022 59 minutes ago, tooldady said: Made it work I had to hide them all with red button then had to show them individually with yellow button even though the yellow button did say hide after showing the first one it did still continue to show. Thank you for the help then you were doing it wrong cause after you hide a category yellow button for that category is show not hide Quote Link to comment Share on other sites More sharing options...
