Hhh Posted November 17, 2022 Posted November 17, 2022 Hello, Earlier I was asked to update from Buzz 4 to Buzz 5 BETA to get the subtitles to work. Did that and they were working when I checked them then. Now - it shows Caption is Disabled. Can someone help me fix this? Thanks Quote
Emporium Posted November 17, 2022 Posted November 17, 2022 Are you sure subtitles are included in the stream you are using ? It won't pull them out of nowhere. In my case, some of my streams have subtitles available, and others don't. So it is spotty. But that is a server issue, not a Buzz issue (in my case at least). And I have another server which has 0 subtitles encoded in the streams. Have you tried with another player (like STBEmu if using MAC sub, or IPTV Smarters if using XC or M3U sub), to see if subtitles are available on your streams ? Quote
dishuser Posted November 17, 2022 Posted November 17, 2022 did you try the other video player in buzztv app? Quote
Hhh Posted November 22, 2022 Author Posted November 22, 2022 I know that my stream includes subtitles. Like i mentioned I was able to see subtitles after getting the Buzz5 Beta. I have not tried any other video player. How do I go about doing that? Quote
Emporium Posted November 22, 2022 Posted November 22, 2022 From LiveTV, hit the Menu button -> Settings ->Configuration And on the top you will see Video Player - LiveTV and it is set to either Primary or Backup. Whatever you have now, select the other one. 1 Quote
Emporium Posted November 22, 2022 Posted November 22, 2022 I just created a small test M3U playlist with 6 channels in it (public streams), which I know transmit with subtitles. On your box, go to menu, settings, server settings, M3U and add an M3U playlist. You can call it "subtest"(or whatever you want) and use the url I sent you in direct message (the url is case sensitive). If it works and you connect, you will see a list of 6 channels (4 english and 2 french). I tested them on my xrs4500 using the latest update 5.0.788 and if I enable subtitles on each channel, I see subtitles as expected. I do need to enable subtitles on each channel (no global settings as far as know, but I could be wrong). Both players (primary and backup) seem to work. But Primary is a little better than the backup one (it's just cleaner the way it shows them), but they both work. I also tested them on my HD5 and they work fine also. Try it and let us know. Quote
Hhh Posted November 22, 2022 Author Posted November 22, 2022 Thank you for the message. I was able to load your playlist and I can see subtitles just fine. When I connect back to my server - I am not seeing subtitles. Upon trying to enable them - it shows DISABLED. So subtitles are DISABLED but CLosed Caption 1 can be enabled , and when I do that I can see subtitles. What am I missing? Thanks for the help Quote
dishuser Posted November 22, 2022 Posted November 22, 2022 15 minutes ago, Hhh said: Thank you for the message. I was able to load your playlist and I can see subtitles just fine. When I connect back to my server - I am not seeing subtitles. Upon trying to enable them - it shows DISABLED. So subtitles are DISABLED but CLosed Caption 1 can be enabled , and when I do that I can see subtitles. What am I missing? Thanks for the help sub titles is closed caption you're missing nothing on one player I get one cc option and on other I get four Quote
Emporium Posted November 22, 2022 Posted November 22, 2022 5 minutes ago, dishuser said: sub titles is closed caption you're missing nothing on one player I get one cc option and on other I get four The Primary player will only show you the actual number of CC choices that are encoded in the stream. So if it has only 2 options, then you will see 2 choices. The Backup player however seems to always show 4 choices as soon as CC is available. And backup player, you don't see the description of the CC stream. Primary player will show you "English", "French", etc.. if multiple CC options are available. Quote
dishuser Posted November 22, 2022 Posted November 22, 2022 8 minutes ago, Emporium said: The Primary player will only show you the actual number of CC choices that are encoded in the stream. So if it has only 2 options, then you will see 2 choices. The Backup player however seems to always show 4 choices as soon as CC is available. And backup player, you don't see the description of the CC stream. Primary player will show you "English", "French", etc.. if multiple CC options are available. doesn't change the fact that subtitles is closed captioning Quote
Emporium Posted November 22, 2022 Posted November 22, 2022 6 minutes ago, dishuser said: doesn't change the fact that subtitles is closed captioning Absolutely. I was just pointing out the differences in how the players react. 1 Quote
David56 Posted January 16, 2025 Posted January 16, 2025 Is there a better streaming box that offers subtitles closed captioning? Quote
