Adjust TV volume?
websurferdude
Hey gang,
I use the x5 remote to adjust volume.  I was using a sound bar controlled using it's remote but it isn't working properly - cutting in & out.  Tried a new optical cable but no joy.  Methinks it's on it's last legs.
So, now I'm left with the volume control on the TV.  Problem is, it only goes to a certain volume & no further.  Oftentimes, because they are doing construction on my apartment building, I need to increase the sound to drowned out the noise & be able to listen to the TV.  Often, this isn't possible because of the issue.
Does anyone have an idea how I can increase the volume?  Is there something in settings I need to adjust??
Thank you for any & all responses!
Regards,
Ray
