Carmen Posted June 15, 2020 Share Posted June 15, 2020 While trying to set up my vidstick, the remote seems to be frozen. When I plug the vidstick, it does the usual stuff (buzz tv, etc) starts but then the screen goes straight to the Smarters app (with cursor on the first line flashing) that I was trying to set up. Nothing I do (take batteries out, unplug vidstick) works! The remote does nothing. Quote Link to comment Share on other sites More sharing options...
whacked Posted June 15, 2020 Share Posted June 15, 2020 During the initial setup, did you go thru the 'Pairing' procedure to pair the remote with Bluetooth ? Quote Link to comment Share on other sites More sharing options...
dishuser Posted June 15, 2020 Share Posted June 15, 2020 why would you load smarters? Quote Link to comment Share on other sites More sharing options...
