Nelutz Posted October 22, 2022 Posted October 22, 2022 (edited) Hi guys ,I downloaded the other day the buzztv beta system update 2.220914 ,FW version V20220919 , and the IPTV version 5.0.779 and I saw that the box doesn't come back from the stand by mode, I have to unplug it from the wall to get the box back to life is there any official update coming for the xrs4500?,I'm still testing it since I got this beta few days a go but this is the most annoying bug that I see for now. Edited October 22, 2022 by Nelutz Quote
Emporium Posted October 22, 2022 Posted October 22, 2022 (edited) BTW: It is no longer Beta. It has been out of beta for quite a while now. The update procedure installs beta first, but them updates to the latest (non-beta 5.0.779 right now). What remote are you using ? IR or BT ? If you are using a BT remote, have you tried just pointing the remote to the box and and using the IR only ? Edited October 22, 2022 by Emporium Quote
Nelutz Posted October 22, 2022 Author Posted October 22, 2022 Ive tried with both ,but seams like it doesn't want to come back from sleep mode ,it comes back but only if I do that within maybe 20-30min after that doesn't want to come back. Quote
