mr man Posted September 19, 2019 Posted September 19, 2019 i have the Buzz 3900 but i see 2 new boxes come out the xr 4000 and the xrs 4000 are those 2 boxes a better box than the 3900. Quote
nbs. Posted September 19, 2019 Posted September 19, 2019 I have both and after a month of using the xr 4000 I prefer the 4000 Right now you cant change mac addy on the 4000 The xrs wont be out till october Quote
Peer Posted September 19, 2019 Posted September 19, 2019 Where do you buy the Buzz Tv boxes and are they better then MAG's? Quote
BigBision Posted September 19, 2019 Posted September 19, 2019 as we play with MAG and Buzztv boxes, it really comes to which is easier on the eyes and easier menus and buzztv well easier on eyes and menus, and stability. where to buy Amazon or worldwidesatellites website.   Quote
osh Posted October 7, 2019 Posted October 7, 2019 On 9/19/2019 at 12:05 PM, Peer said: Where do you buy the Buzz Tv boxes and are they better then MAG's? i have access to them, just bought the 4000, i like it Quote
osh Posted October 7, 2019 Posted October 7, 2019 On 9/18/2019 at 9:52 PM, nbs. said: I have both and after a month of using the xr 4000 I prefer the 4000 Right now you cant change mac addy on the 4000 The xrs wont be out till october thats sucks! i also found out its not the mac address you input for iptv but its the servers id Quote
BigBision Posted October 7, 2019 Posted October 7, 2019 8 minutes ago, osh said: thats sucks! i also found out its not the mac address you input for iptv but its the servers id The Server ID is proper wording, MAC do not start with Number 00 it always should start with Letter D or E or C.  1 Quote
nbs. Posted October 26, 2019 Posted October 26, 2019 (edited) On 10/7/2019 at 11:03 AM, BigBision said: The Server ID is proper wording, MAC do not start with Number 00 it always should start with Letter D or E or C. I input the mac addy when i set up iptv Really dont know what you are talking about  Edited October 26, 2019 by nbs. Quote
nbs. Posted October 26, 2019 Posted October 26, 2019 1 hour ago, nbs. said: Â my bad ,just noticed they way they have it listed at top right 1 Quote
