Ricco Posted October 16, 2022 Posted October 16, 2022 Hi guys i own a vidstick max which us 128gb and a xrs4500 with 64gb internal storage,Just wondering as both have been updated to buzz 5 and recording stuff ,i wanna record a few things and also some movies etc would i be better to get the u5 or would it make no difference to download speeds etc..takes ages to download a film to internal storage i have 60 mbps internet.basically is recording onto hhd or ssd offer a better recording experience than onto my vidstick max internal 128 gb.i know loads about buzztv but struggle with recording etc also record one and watch other one is that on all buzz5 update or just the new boxes coming out i know about your service provider u needs 2 connections.hopefully someone can help.cheers Quote
dishuser Posted October 16, 2022 Posted October 16, 2022 I have no issues recording/downloading to internal or external 1 Quote
sea157 Posted October 16, 2022 Posted October 16, 2022 I have no problem recording and watching another channel on my xrs4500 with 64gb internal storage or my U5 with 1 TB hard drive. As a matter of fact I have one service provider that allows me to have 4 feeds and last week just as an experiment I was recording 3 channels and watching the 4th channel live on my xrs4500 with 64gb internal storage, all 3 channels recorded successively while I was watching the 4th channel live with the Buzz 5 program. These people did a GREAT job on the Buzz 5 program!! 2 Quote
Ricco Posted October 17, 2022 Author Posted October 17, 2022 Wow thats great i was thinking of getting the x 5 to replace my xrs4500 but apart from av1 codec cant see the point,if you download a film is it quicker downloading to hhd on you u5 or same as internal storage?im in uk u5 not on sale yet i could buy via buzz global. Quote
sea157 Posted October 17, 2022 Posted October 17, 2022 9 hours ago, Ricco said: Wow thats great i was thinking of getting the x 5 to replace my xrs4500 but apart from av1 codec cant see the point,if you download a film is it quicker downloading to hhd on you u5 or same as internal storage?im in uk u5 not on sale yet i could buy via buzz global. Other then the extra storage the U5 has over the XRS4500 I see no difference in the operation of it. The XRS4500 running the latest Buzz 5 program is an amazing box! Now the XRS4500 running the Buzz 4 program that is a different store, I could NEVER record anything the way you should have been able to with the Buzz 4 program but with the Buzz 5 program it performs like it was made to! If you have it turned off it will even wake up to record a program you have scheduled to record if it is running the latest version of the Buzz 5 program.. Quote
Ricco Posted October 17, 2022 Author Posted October 17, 2022 Thanks for info my remote has tonight gone awol,flashing etc... On and off press blue to stop but back again killling the batteries.anyone know if the bt400 works with xrs4500. Quote
dishuser Posted October 17, 2022 Posted October 17, 2022 6 minutes ago, Ricco said: Thanks for info my remote has tonight gone awol,flashing etc... On and off press blue to stop but back again killling the batteries.anyone know if the bt400 works with xrs4500. did you pair bt? Quote
Ricco Posted October 17, 2022 Author Posted October 17, 2022 Yea im pretty sure its done for now. Quote
