Fossil Posted June 8, 2020 Posted June 8, 2020 Has anyone had problems with channels not loading? A couple of times a day - the spinning wheel will show up and the channel won't load. Switching to other channels will load the new selected channels, but not always. Once they don't load, they stay off for hours at a time. Rebooting doesn't help. I am at a loss. -Fossil Quote
Fossil Posted June 9, 2020 Author Posted June 9, 2020 That's what is running through my head, but I am on a site where there are a bunch of other users using the same type of box and nobody else seems to be having problems like this. I don't want to pay for another service unless I am sure that its not a problem with the box. Quote
nbs. Posted June 9, 2020 Posted June 9, 2020 ok its not more channels loading when you change channels ,its the info for those channels All channels are loaded when you connect to the server you could always try a factory set and reload your server info Quote
Fossil Posted June 9, 2020 Author Posted June 9, 2020 (edited) I'll give that a try tomorrow. Thanks for the reply and the tip. I'll be sure to let you know how I make out. BTW - how do i do a factory reset on this box? Edited June 9, 2020 by Fossil added question Quote
Fossil Posted June 10, 2020 Author Posted June 10, 2020 That seems to have hit the spot. Thanks for the help. Quote
