Sal Posted May 28, 2020 Share Posted May 28, 2020 Hello, I have an XPL 3000. Have been reading, and notice under configuration, you can choose your buffer time from 0-10 SEC. Can someone please assist, which one I should select. Also, would help if I can get more details on what that means. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
allaboutbuzz Posted May 28, 2020 Share Posted May 28, 2020 21 hours ago, Sal said: Hello, I have an XPL 3000. Have been reading, and notice under configuration, you can choose your buffer time from 0-10 SEC. Can someone please assist, which one I should select. Also, would help if I can get more details on what that means. Any help would be appreciated. 3 seconds is usually a good setting If you're experiencing any freezing though, then you can try to go higher. Or if you have a slower internet connection, this helps as well. Quote Link to comment Share on other sites More sharing options...
