Flyinghigh Posted July 17, 2022 Posted July 17, 2022 My Vidstick Max is losing connection, pausing, slow motion and out of sync. I have attached a small video to see the signal dropping. Also, a pic of settings. This stick is connected to the same Wi-Fi as my x5. X5 is fine on same channel. 20220717_110748(1).mp4 Need a bit of help getting her rolling, please. Quote
dishuser Posted July 17, 2022 Posted July 17, 2022 what's the speed at the stick? what are you using for power? 1 Quote
Flyinghigh Posted July 17, 2022 Author Posted July 17, 2022 Analiti is showing 35 Mbps. Lower than normal. I am plugged into the outlet. Quote
Flyinghigh Posted July 17, 2022 Author Posted July 17, 2022 UPDATE......... This appears to only be happening on a couple channels. This happened yesterday as well, but on a different channel. Maybe it needs to settle in? Quote
Flyinghigh Posted July 17, 2022 Author Posted July 17, 2022 (edited) Seems I cut off the right side. Buzz System Update shows 2.211105 Edited July 17, 2022 by Flyinghigh Quote
Flyinghigh Posted July 17, 2022 Author Posted July 17, 2022 Sure. How do I do that? I just got the stick this week. Quote
PapaS Posted July 17, 2022 Posted July 17, 2022 15 minutes ago, Flyinghigh said: Done. This may be related to the latest version of analti. Alot of people talking about this on another streaming forum. You might want to try a different speedtest app or use older version of analti. Hope this helps, good luck 1 Quote
dishuser Posted July 17, 2022 Posted July 17, 2022 11 minutes ago, PapaS said: This may be related to the latest version of analti. Alot of people talking about this on another streaming forum. You might want to try a different speedtest app or use older version of analti. Hope this helps, good luck I always update and have no issues with tests 1 Quote
Flyinghigh Posted July 17, 2022 Author Posted July 17, 2022 Thanks, Papa. I read that thread as well. Wasn't so hooked on the speed result. Darn thing just keeps stopping, freezing, getting out of sync. All kinds of crazy stuff. 1 Quote
dishuser Posted July 17, 2022 Posted July 17, 2022 6 minutes ago, dishuser said: I always update and have no issues with tests and latest version is only an hour old 1 Quote
preciousboo80 Posted July 24, 2022 Posted July 24, 2022 Send it to my email address so I can update my Buzztv vidstick max 1 Quote
nbs. Posted July 24, 2022 Posted July 24, 2022 They can't do it that way You have to send them your mac and current firmware Quote
Flyinghigh Posted July 24, 2022 Author Posted July 24, 2022 Here is an update on my Vidstick Max. I have reset the stick. Added VPN and apps. Turned on TS. Problem is pausing and out of sync. This is happening on my 2 Buzztv devices. The vidstick is what I am talking about here. There are several channels that are not watchable. I am watching a baseball games today. The local network channel will not play without pausing. It is even out of sync when it shows and says something. I change to the MLB channel for the home team channel. Still won't play. Tune to the away feed MLB channel, and it plays fine. So what the heck does this mean? I have even gotten a 24hr trial of another provider. It is doing the same thing with that channel. There is another issue on both boxes. The spinning wheel will sometimes stay on the screen. It's on there now. I need some ideas on this one. What needs to happen here? Quote
nbs. Posted July 24, 2022 Posted July 24, 2022 Usually if some channels play fine and others don't it's a server issue 1 Quote
