gmat88 Posted March 16, 2020 Posted March 16, 2020 I am using BuzzTV build 347. Some channels say "Unknown stream format". When I switch to secondary player they say "media not supported". On new player I get the "stream is not available. Please try again later". Channels work fine on a friend's firestick set-up, same provider. Can you please advise? Tried a hard reset of the box and no go. Quote
Buzztvguy Posted March 16, 2020 Posted March 16, 2020 (edited) What server are you using, that is the most likely issue, unless your IPTV server is running true HD content then you'll need EXO Player. What player is you friend using on the (________ ) ? (_____) (____) or (____XXXXXX) or other ? Edited March 19, 2020 by BigBision words that are not allowed. Quote
BigBision Posted March 19, 2020 Posted March 19, 2020 On 3/15/2020 at 9:27 PM, gmat88 said: I am using BuzzTV build 347. Some channels say "Unknown stream format". When I switch to secondary player they say "media not supported". On new player I get the "stream is not available. Please try again later". Channels work fine on a friend's firestick set-up, same provider. Can you please advise? Tried a hard reset of the box and no go. that do not sound like buzztv app or box issue, if you are still experiencing that problems then contact your sellers. Quote
Lanceer592 Posted March 24, 2020 Posted March 24, 2020 I’m having the same issues but only with one server everything loads but it says unknown streaming format try again later. Quote
allaboutbuzz Posted March 24, 2020 Posted March 24, 2020 1 hour ago, Lanceer592 said: I’m having the same issues but only with one server everything loads but it says unknown streaming format try again later. Usually means the channel is down when that happens. Quote
