nitronist Posted June 22, 2022 Share Posted June 22, 2022 Is there a way to factory reset the BT-200 Remote Controller? I tried to pair the remote but the whole remote is flashing after clicking the OK button and Volume - at the same time. The Red LED remote should be flashing 3 times but is doesn't do that. Quote Link to comment Share on other sites More sharing options...
dishuser Posted June 22, 2022 Share Posted June 22, 2022 did you try different batteries? Quote Link to comment Share on other sites More sharing options...
nitronist Posted June 22, 2022 Author Share Posted June 22, 2022 1 hour ago, dishuser said: did you try different batteries? I tried fresh batteries just now and it worked thanks! 2 Quote Link to comment Share on other sites More sharing options...
