lawrence c Posted June 2, 2022 Posted June 2, 2022 when changing channel or using last it will freeze and circle and eventually open up the channel. this is the only issue i am having since the last few updates. Does not happen every time. Quote
nbs. Posted June 2, 2022 Posted June 2, 2022 clear cache? close running apps? Have you tried other media player? Quote
lawrence c Posted June 3, 2022 Author Posted June 3, 2022 tried clearing cache. I am using secondary player. Default is worse. when on full screen and using last channel will circle for about 15 20 seconds the channel appears. Not a big issue but can be annoying. rebooted and same thing. Maybe will have to do a reset and se what happens. Quote
lawrence c Posted June 3, 2022 Author Posted June 3, 2022 did a reset and that so far seems to solved the issues along with the other updates running well now. Having some issues with provider with tv series. log in one time all working log in later a couple episodes won't load. will have figure that one out. thanks for you attention Quote
nbs. Posted June 3, 2022 Posted June 3, 2022 22 minutes ago, lawrence c said: did a reset and that so far seems to solved the issues along with the other updates running well now. Having some issues with provider with tv series. log in one time all working log in later a couple episodes won't load. will have figure that one out. thanks for you attention That is usually a server issue too Quote
