XRS4000 with ARQ100
Hello,
I bought the remote control arq100, I use it with the XRS4000 but the keyboard does not work in vod and serie, I type on the keys of the remote control but that does nothing. The keyboard works on google chrome or other application but does not work on Buzztv4.
Do you have a solution please ?
Thank you.
  • 4 weeks later...
  On 1/1/2020 at 2:40 PM, staff49 said:
Thanks to the technical team, the keyboard works now.
Arq100 is the best remote control for Buzztv boxes.
I am very happy with my purchase
Expand
Can you share how it works?because I have the same problem.
  On 1/29/2020 at 5:20 PM, nbs. said:
dont know why, Its the updates on the 4000 that fixed the remote
Maybe uninstall updates and reinstall?
Expand
I have the latest update on mine ,hmmm so should I uninstall the Buzztv app and install that again? I will check out with different server
