I just received my E2 the other day and there are couple of things that nag me:
- The channel  display digits seem limited to 4 digits, i.e. in the guide it shows 12034 but at the bottom  of the OSD it only shows 1203.
- Is there any way to get the feed specs through Info or some other mean (i.e.  we have no idea if the feed is SD/HD/FHD or 4K or if the codec is MP4 or HEVC). My previous box displayed that information when pressing Info a couple of times.
Thank you.
Edited by JC1
  On 4/27/2022 at 4:48 PM, nbs. said:
Hit the menu button while watching tv and post the version info at bottom
Expand
4.0.524 January 18th 2022
The problem is that the provider has 5 digits channels. For the Info, all I get is first the bottom OSD and then I get the program description.
