kielbear Posted February 7, 2020 Posted February 7, 2020 On 2/3/2020 at 5:23 PM, nbs. said: kuulmedia is the european distributor. Are you in europe? Yes.. Kuul media have informed me that they can´t do anything for me as Buzztv only give a 60 day warranty on the remote... which isn´t so good to put it politely. Quote
nbs. Posted February 7, 2020 Posted February 7, 2020 I have been involved in satellite for many years and the main players did not warranty the remotes sonicview viewsat dreamlink etc 2 Quote
hdv Posted March 8, 2020 Posted March 8, 2020 Same problem here with some of the boxes. Changing the remote didn't work for me, but switching television worked with those boxes I have with remote issues. This just verifies that there is an issue with these boxes that need to be addressed. Quote
nbs. Posted March 8, 2020 Posted March 8, 2020 (edited) so you are saying changing televisions affects the remotes? Edited March 8, 2020 by nbs. Quote
hdv Posted March 12, 2020 Posted March 12, 2020 I know it sounds crazy as the television has nothing to do with the remote in my opinion. But when I switch the problem 4000 to a different Tv, voila... the remote works with that television. There is definitely a problem with some of the boxes and Buzz need to figure that one out quickly. Quote
Shoma Posted March 13, 2020 Posted March 13, 2020 (edited) I had a BuzzTV 3000 remote and it worked like a charm with my Samsung tv. Two Buzz 4K remotes ( original and illuminating) both have these issues though the illuminating less than the original. A fake buzz remote from Artronix also works without any problems. PS Buying a new tv to fix remote problem is not an option Edited March 13, 2020 by Shoma 1 Quote
Shoma Posted March 17, 2020 Posted March 17, 2020 To confirm hdv’s finding, I moved my buzz 4K to an older, non-smart tv and the original remote works fine. I was flipping through buzz for 10-15 minutes and no delays at all. So, it might be an interference from a tv after all. Btw, the tv I was having issues with is a one year old Samsung. Hope this helps the Buzz team further troubleshoot this issue. 1 Quote
G2P Posted March 17, 2020 Posted March 17, 2020 2 hours ago, Shoma said: To confirm hdv’s finding, I moved my buzz 4K to an older, non-smart tv and the original remote works fine. I was flipping through buzz for 10-15 minutes and no delays at all. So, it might be an interference from a tv after all. Btw, the tv I was having issues with is a one year old Samsung. Hope this helps the Buzz team further troubleshoot this issue. I have samsung Too and have same issue 1 Quote
Sally15 Posted March 23, 2020 Posted March 23, 2020 Do these TVs have LED or fluorescent backlight? LED backlight TVs I have not seen cause the issue. Fluorescent backlit TVs I have seen cause the issue. Depends on the frequency the backlight of the inverter running the backlight. Quote
Shoma Posted March 24, 2020 Posted March 24, 2020 How can I find out? Because I have no clue about that stuff Quote
G2P Posted March 24, 2020 Posted March 24, 2020 8 hours ago, Sally15 said: Do these TVs have LED or fluorescent backlight? LED backlight TVs I have not seen cause the issue. Fluorescent backlit TVs I have seen cause the issue. Depends on the frequency the backlight of the inverter running the backlight. I have fluorescent backlight on Samsung TV Quote
Fossil Posted March 24, 2020 Posted March 24, 2020 The remote that came with my XRS4000 was the worst. Scrap #1. I then bought an IR-1000L. It was just as bad as the original. 3 or 4 key presses to get a response. The pretty little red light on the unit flashed with each key press, but that was all that happened. Scrap #2. Then I purchased the ARQ-100, and what a difference. This unit is super responsive ,and each key press produces a quick result. If you are looking for a super replacement, spend the extra few bucks and buy the ARQ-100. Oh yeah - it also comes with a free keyboard on the back. 1 Quote
nbs. Posted March 24, 2020 Posted March 24, 2020 I have no issues with either of those remotes and there is very little negative feedback on the other two forums I visit Quote
G2P Posted March 25, 2020 Posted March 25, 2020 On 3/17/2020 at 3:42 PM, Shoma said: To confirm hdv’s finding, I moved my buzz 4K to an older, non-smart tv and the original remote works fine. I was flipping through buzz for 10-15 minutes and no delays at all. So, it might be an interference from a tv after all. Btw, the tv I was having issues with is a one year old Samsung. Hope this helps the Buzz team further troubleshoot this issue. It may be, but the same remote was working fine with same TV for few weeks, so it may be something else Quote
G2P Posted March 25, 2020 Posted March 25, 2020 On 3/23/2020 at 6:43 PM, Sally15 said: Do these TVs have LED or fluorescent backlight? LED backlight TVs I have not seen cause the issue. Fluorescent backlit TVs I have seen cause the issue. Depends on the frequency the backlight of the inverter running the backlight. the same remote was working fine with same the TV for few weeks, so it may be something else Quote
Gualdo Posted May 31, 2020 Posted May 31, 2020 Bought the XRS box a couple of months ago, put it on a less than a year old Samsung TV, and oh boy, same issues as described before, press keys 4, 5 or more times to get it going. FRUSTRATING to say the least. Quote
Rinny1 Posted May 31, 2020 Posted May 31, 2020 I’ll look into this I also have people with remote problems !! Very interesting finds on the Samsung TVs Quote
Shoma Posted May 31, 2020 Posted May 31, 2020 Same issue. I’m using an old Buzz 2K remote and it works well. Not all buttons work though, one being EPG. Quote
nbs. Posted May 31, 2020 Posted May 31, 2020 (edited) 1 hour ago, Gualdo said: Bought the XRS box a couple of months ago, put it on a less than a year old Samsung TV, and oh boy, same issues as described before, press keys 4, 5 or more times to get it going. FRUSTRATING to say the least. there are two xrs remotes one for the 4000 ,and one for the 4500 which one do you have? Edited May 31, 2020 by nbs. Quote
Onbase Posted June 1, 2020 Posted June 1, 2020 17 hours ago, Rinny1 said: I’ll look into this I also have people with remote problems !! Very interesting finds on the Samsung TVs Rinny are you connected through wifi? I you are don't select 5G use 2.4 and see if that helps. Quote
Onbase Posted June 1, 2020 Posted June 1, 2020 17 hours ago, Rinny1 said: I’ll look into this I also have people with remote problems !! Very interesting finds on the Samsung TVs Quote
Onbase Posted June 1, 2020 Posted June 1, 2020 If you're connected through wifi don't select the 5G try 2.4 see if that helps ...it did for me. Quote
Rinny1 Posted June 2, 2020 Posted June 2, 2020 14 hours ago, Onbase said: If you're connected through wifi don't select the 5G try 2.4 see if that helps ...it did for me. Ok thanks Quote
