How to play 5.1 surround audio
Hi all, I have had the 4000 for some time. I cannot figure out how to stream anything other than 2.0. Can someone help to tell me if all the content is simply in 2.0 or am I not doing something properly.
1 hour ago, mysetv said:
You’ll find most streams are just 2.0
2 hours ago, Rpm said:
Anyone?
With mine I connect it to a home theater system and there if the stream or video with 5.1 the receiver of the home theater will do that for me 😁 ,I think for the 5.1 the box has to have a special chip 🙂👍
19 hours ago, Rpm said:
Anyone?
Majority of streams from IPTV are in 2.0 Audio
If you have a stream that is broadcast in Dolby or DTS, the Buzz app is capable of streaming it using Software Decoding through FFMPEG.
Interesting. My system is hooked up to a avr with atmos but I have yet to find a stream other than 2.0. And at that the audio is bad in comparison to the video
