On two occasions I've turned on my xrs4500, and the audio stream starts, then the live TV with audio starts. I have two audio streams at the same time; the first audio about 3 seconds behind the audio with video. If I change the channel I get the new audio and video, but the first audio doesn't stop or change. I'm using the Buzz5 beta, live TV set to default player, VOD on secondary, power on set to start in live TV (but off in configuration/settings). I can't figure out what's causing this, does anyone have any suggestions?
Thanks.
  • 4 weeks later...
