Rodie Posted March 14, 2022 Share Posted March 14, 2022 (edited) since update 653 on Xrs 4900 I noticed when on epg guide I scroll one at a time and it will start moving so fast you cannot read them! The remote button is not stuck. When this happens I cannot stop it, it will stop on it's own. Everything else is working great Edited March 14, 2022 by Rodie Forgot to add Quote Link to comment Share on other sites More sharing options...
nbs. Posted March 14, 2022 Share Posted March 14, 2022 Check your battery level It will happen to me when it's low Quote Link to comment Share on other sites More sharing options...
Rodie Posted March 14, 2022 Author Share Posted March 14, 2022 40 minutes ago, nbs. said: Check your battery level It will happen to me when it's low Hi nbs just checked batteries with meter showing 1.40 volts Also remote light is off Quote Link to comment Share on other sites More sharing options...
nbs. Posted March 14, 2022 Share Posted March 14, 2022 You can check in the menu under remotes and accessories Quote Link to comment Share on other sites More sharing options...
Maestro701 Posted March 15, 2022 Share Posted March 15, 2022 Mine does this even though battery percentage is in the 60s but not too often. Like once in a blue moon Quote Link to comment Share on other sites More sharing options...
