225 Posted January 31, 2022 Posted January 31, 2022 I will be watching a channel for a few then my audio will cut out but video is fine, I can fix it by changing channel then come back? 1 Quote
nbs. Posted January 31, 2022 Posted January 31, 2022 (edited) Have you tried both media players? Menu settings,config Edited January 31, 2022 by nbs. 1 Quote
225 Posted January 31, 2022 Author Posted January 31, 2022 no not yet, I have live tv set as default at the moment 1 Quote
Maestro701 Posted January 31, 2022 Posted January 31, 2022 11 minutes ago, 225 said: no not yet, I have live tv set as default at the moment Try secondary player see what happens but they've been some reports of this player behaving the same way. Quote
225 Posted January 31, 2022 Author Posted January 31, 2022 Ok, I changed live tv to secondary and now the picture keeps freezing but audio continues. 1 Quote
Rinny1 Posted January 31, 2022 Posted January 31, 2022 It’s the server your using I bet you try a different channel it’s fine 1 Quote
Maestro701 Posted January 31, 2022 Posted January 31, 2022 8 hours ago, 225 said: Ok, I changed live tv to secondary and now the picture keeps freezing but audio continues. Mine don't freeze but it stutters/lag. It only happens on FHD channels. Check the info bar bottom right hand corner where it says HD FHD SD. What does yours say on the channels that freeze up? Quote
225 Posted January 31, 2022 Author Posted January 31, 2022 im using buzz tv 5 and I dont see those on my info bar ? Quote
Rinny1 Posted January 31, 2022 Posted January 31, 2022 Yes I see that info FHD and HD bottom right on the info bar I’ll test out 1 Quote
dishuser Posted January 31, 2022 Posted January 31, 2022 2 hours ago, 225 said: im using buzz tv 5 and I dont see those on my info bar ? you need to use secondary to see that Quote
Rinny1 Posted February 1, 2022 Posted February 1, 2022 Never really had a problem on FHD channels many problems server related 1 Quote
Maestro701 Posted February 1, 2022 Posted February 1, 2022 21 minutes ago, Rinny1 said: Never really had a problem on FHD channels many problems server related I didn't have any issues before the beta release. My channels streams have crisp picture, it doesn't say FHD for nothing . It's as clean as you can get. But let's hope all things are ironed out soon 1 Quote
Rinny1 Posted February 1, 2022 Posted February 1, 2022 Ok interesting be sure allaboutbuzz knows and your service was 1 Quote
Maestro701 Posted February 1, 2022 Posted February 1, 2022 9 hours ago, Rinny1 said: Ok interesting be sure allaboutbuzz knows and your service was Cant talk about services here, not allowed but it's good. Quote
Lovebuzztv Posted February 1, 2022 Posted February 1, 2022 Bonjour Ces normale avec la bêta il y a un problème de codec (ac3) Fhd ou hd ces pas le problème regarder quel codecs déconne plutôt Les deux lecteurs ne sont plus aussi bon Quote
Bobby1rai Posted February 2, 2022 Posted February 2, 2022 i have the same issue some channel audio works on default and some channels audio works on secondary. let me know if someone solve this problem. 1 Quote
nbs. Posted February 2, 2022 Posted February 2, 2022 35 minutes ago, Bobby1rai said: i have the same issue some channel audio works on default and some channels audio works on secondary. let me know if someone solve this problem. buzz have to fix the issue ,its been posted about many times 1 Quote
225 Posted February 14, 2022 Author Posted February 14, 2022 On 2/2/2022 at 9:16 AM, nbs. said: buzz have to fix the issue ,its been posted about many times ok , I will check back soon and see if there is a fix yet, i switch to t mate for now. Quote
