DMJ Posted 11 hours ago Posted 11 hours ago I have been using buzz5 beta on my vidstick max for months now and has been working great but this week an update came thru and I’ve lost my epg guide on my Mac server only. Works on my XC. Can someone help. My provide says it’s on my end. Thanks Quote
Emporium Posted 10 hours ago Posted 10 hours ago First of all, it is not a "beta". It has not been a beta for nearly 5 years now What version are you running now (hit menu button, and should be on bottom left). Latest version is 5.0.961 For your EPG issue, have you tried to "CLEAR EPG" to see if it repopulates ? If EPG gets corrupted for some reason, it may fail to subsequently update, so you may need to clear it. Should be in the menu->settings->configuration if you scroll down to the EPG section. After you select "CLEAR EPG" give it 4 or 5 seconds, until you get the message saying it was cleared, before returning to main video screen. 1 Quote
DMJ Posted 1 hour ago Author Posted 1 hour ago Thanks for the quick response. I gave the clear Epg a try but that didn’t work. And yes I do have the latest version of iptv 5.0.961. Any other suggestions Quote
Emporium Posted 12 minutes ago Posted 12 minutes ago Try creating a new server entry. You can call it whatever you want (myserver2) and see if this newly created entry will download the program guide. Quote
