JlC Posted January 28 Posted January 28 Upgraded from an older Samsung led tv to a new 83" LG C5, new 2.1 certified HDMI cables new LG S90TY Soundbar all new correct length network cables etc. For some reason when watching any content on the PS 6 after sometime 20 mins or so the LG screen goes blank and shortly indicates no signal, if I hit the middle round button on the BT 500 remote it comes back on and continues playing just fine. I have all power saving functions turned off on the TV and PS6. This is really frustrating knowing I could have bought a much cheaper Android based hardware box for how it performs and now this which is making the device unusable in my opinion. Hooked my old Nvidia Shield Pro 2019 up and no issues at all. Any thoughts? 1 Quote
pugsycan Posted January 29 Posted January 29 1 hour ago, JlC said: Upgraded from an older Samsung led tv to a new 83" LG C5, new 2.1 certified HDMI cables new LG S90TY Soundbar all new correct length network cables etc. For some reason when watching any content on the PS 6 after sometime 20 mins or so the LG screen goes blank and shortly indicates no signal, if I hit the middle round button on the BT 500 remote it comes back on and continues playing just fine. I have all power saving functions turned off on the TV and PS6. This is really frustrating knowing I could have bought a much cheaper Android based hardware box for how it performs and now this which is making the device unusable in my opinion. Hooked my old Nvidia Shield Pro 2019 up and no issues at all. Any thoughts? know you said new HDMI but like Maestro said try another Could be a bad one But if it is still doing it I would save all you settings and servers and do a factory reset as it may have something corruped in it 1 Quote
JlC Posted February 10 Author Posted February 10 New certified hdmi 2.1 cables were no help, this only started after new tv and the only other thing that changed was the android resolution since my old tv only did 1920x1280. Gonna reset it, if that doesn't work guess I wasted $500 and going back to my Shield Pro. Quote
