Hey everyone, I've been using a couple of Bluetooth devices for audio with the P6 device and have been having sync issues,specifically using the Buzz TV 6 app. The video and audio is out of sync, the video is about 2 seconds ahead of the audio, very noticeable and hampers your viewing experience.
However, using the Buzz 5 app and any other app on this same device, everything works perfectly. Like I said before I've tried it with 2 different Bluetooth devices and get the same result.
I asked a friend to try their device and they experienced the same thing. Furthermore, they said using the Buzz TV 6 VOD when they use the internal player everything is out for sync but with the external player it works fine.
Could it be an issue with the audio processing on the primary (and only) internal player on buzz TV 6 app?
1 hour ago, dishuser said:
I have no issues using primary with a 2.1 sound system
Is it Bluetooth? Can you send me the link to this product so I can buy it. Thanks
it's a samsung
https://www.samsung.com/us/televisions-home-theater/home-theater/sound-bars/b-series-2-1ch-dts-virtual-x-soundbar-hw-c445-hw-c445-za/
I ordered it online from bestbuy using a 3rd party
was around $200 and got it for $90
Edited by dishuser
  • Thanks 1
it's a samsung
Thanks
You have it connected to Bluetooth compatible TV as well?
3 minutes ago, Maestro701 said:
Thanks
I have it connected to my p6 using bluetooth
and use optical for my x5ss to save time pairing it
  • Thanks 1
I tried last night using an Anker Soundcore BT speaker, another cheap chinese no name brand one, and my Poly Voyager 2 headsets, and with all 3 the result was the same.  When using BuzzTV 6, things were all slightly out of sync.
Watching same programs/streams On BuzzTV 5 (on the P6), everything was perfectly in sync.
Also Tested on some VOD, and using the internal player of BuzzTV 6, movies were slightly out of sync also, but using external player (I used MX Player), everything was in sync.
I will try to test a few more BT devices on the weekend.
  • Thanks 1
