everton Posted January 19 Posted January 19 I watch my B5 and turn it off, I turn it on 2 days after and the blue light comes on but no signal display on the tv the tv is showing no signal i try more than one hdmi cables and still no signal on the tv and it is connect to the correct source mode i also have a friend who is having the same issue with a same B5 model any help would be appreciated. Quote
Emporium Posted January 19 Posted January 19 I'm assuming you have unplugged the power on the unit for a few seconds and then tried to plug it back in ? Just as a test, have you tried plugging it into a different TV/Display ? If you have a computer monitor that has an HDMI input, maybe as test just try to plug it into that. 1 Quote
