Lawrence Calhoun Posted October 14 Posted October 14 This is the same IPTV i use on my U5. It doesn't play adult channels with timeshift on I turned on the feature to allow Adults to play as favorites It will work for 2 channels and then i get a timeshift error stream not found Quote
Emporium Posted October 14 Posted October 14 Timeshift does NOT work with all streams. Are you using TS or HLS streams ? And if your drive is toast (from the sounds of the other post you made - in the wrong section), then obviously timeshift will not work. 2 Quote
