Kone Posted August 17, 2025 Posted August 17, 2025 Is it possible to remotely connect to someone box to configure adjust add server portal settings ? Quote
Emporium Posted August 17, 2025 Posted August 17, 2025 (edited) Pretty sure most boxes come with TeamViewer installed. You can use that. Butting adding portal and stuff on Buzz boxes is so simple. Even guided seniors (non-tech savvy) through the task and it wasn't that difficult.. Edited August 17, 2025 by Emporium 1 Quote
