BuzzTV 5 is the IPTV software that runs on a number of boxes (From Android 9 up to Android 13).  The feature you are looking for is an OS feature, so this should have been posted in the forum for the specific BOX you have (4000 series [4500, 4900, ..], 5 series [B5, E5, Classic, X5, etc..], or other).
Truth is, once you try to install an app that needs the permission enabled, it would give you a popup, and then when you select it, it typically opens the permission screen, and you scroll down, find the file manager/browser you were using to install the apk, and enable the permission for that app.
