MMJ Posted March 17 Author Posted March 17 Followed your instructions and even restarted the box subsequently but, still no improvement. Quote
Emporium Posted March 17 Posted March 17 Try creating a new server entry (you can use the same URL and user/password as the one you already have). And see if using the new server entry seems any better. PS: Are you sure you have not changed your default players ? If you go into the menu->Settings->Configuration, what are your LiveTV and VOD/TVSeries players set 2 (they should be the first 2 options on top). LiveTV should ideally be set to "Primary" for best performance. Quote
MMJ Posted March 17 Author Posted March 17 Live TV is set to "Primary" and VOD+TV Series is set to "Backup". However, I found an option called "Tunneled Playback" ON which I turned OFF now. Let me check if things improved. In the meantime please let me know if the servers are configured correctly or they need any adjustment? Quote
