allinghj Posted April 2, 2025 Posted April 2, 2025 When I go to search, and start typing in a channel name, the letters repeat....like aaa. Can I slow down the speed so that doesn't happen? Quote
Emporium Posted April 2, 2025 Posted April 2, 2025 I do not have such an issue. What remote are you using ? A little more info would help. If it is the standard BT250 that came with the Classic, then there is obviously something wrong with the remote. If it is paired (Bluetooth) try to unpair/forget it, and re-pair it. When you unpair it (before re-pairing it), can you try with just IR and see if the same persists ? 1 Quote
allinghj Posted April 3, 2025 Author Posted April 3, 2025 It's the upgraded remote with the keyboard. Actually I think I may have solved the issue. I used the "pointer speed" setting to slow down the pointer and I think it may have also slowed down the typing...no repeating letters so far. Quote
dishuser Posted April 3, 2025 Posted April 3, 2025 12 minutes ago, allinghj said: It's the upgraded remote with the keyboard. Actually I think I may have solved the issue. I used the "pointer speed" setting to slow down the pointer and I think it may have also slowed down the typing...no repeating letters so far. so it's one of 4 remotes...lol 1 Quote
allinghj Posted April 3, 2025 Author Posted April 3, 2025 And here I thought my fancy remote put me in the "elite" club. Is there a model number on it some where? 1 Quote
dishuser Posted April 3, 2025 Posted April 3, 2025 17 minutes ago, allinghj said: And here I thought my fancy remote put me in the "elite" club. Is there a model number on it some where? https://buzztvglobal.com/en-ca/collections/remotes Quote
